jhorton3
I got the top back on the car and installed a new rubber header seal. I can get the left and right side latches to latch down on the windshield frame with some effort. The problem is twofold. First the center of the top's header bows upward leaving a gap between the windshield frame and top seal of about 1/8" if not more. The second issue is the left corner of the top header interferes with the left door's vent window frame, causing the vent window to stick out. Luckily I haven't fastened everything down on the frame to the door.
Is there something I can adjust to bring these two problems back in alignment?
