Nunyas
After what seems like hours of trying to figure out the proper numbers to put in a "1920x1080@60Hz" "modeline" that works and make Ubuntu use it by default, I found that I had been racking my brain for no reason. I still don't have internet access setup at the new hovel, so I was trying to remember the calculations to generate the "modeline" I wanted.
Finally, I relented to reading the "man page" on "xorg.conf" and after my first read I didn't come away with any "useful" information. An hour later, I looked at it again and ended up re-reading a two sentences a 5 or 6 times trying to make sense of it, when the meaning of the sentence clicked: "<span style="font-weight: bold">ModeLine:</span>...In most cases this isn't necessary because the built-in set of VESA standard modes will be sufficient." and something about "DDC will be used to determine compatible resolutions if there are no 'modeline' entries".
Right away, I opened my "xorg.conf" file and added a "#" at the beginning of every "modeline" entry my file had (commented out all of my configured "modelines"). I followed that up with deleting all entries I had in the "Section 'Screen'">"SubSection 'Display'" area. Finally, I added a single entry to this subsection: "1920x1080@60".
I found the solution for running Linux at 1080P to be deceivingly obvious and simple. It had been so long since I fuddled with an X configuration file that I was attempting to manually generate stuff that was unnecessary for modern versions of Linux.
I followed the HDTV setup with connecting my wireless KB and Mouse to the system.
Now all I have to do is figure out what the heck is going on with my 6Mb DSL order, and the geek in me will be happy
