startech47
Is the housing or hub bent near the wheel? That would stress the axle on every rotation. Insert the new axle with no o-ring or gasket and check to see if the is a gap anywhere when you hold the axle in by hand. If the housing or hub is bent you will have one area that is touching that gets progressively larger to the point that is 180 degrees away from the point that they touch. If you keep looking as you continue around the gap will decrees until you get to the point of contact. Do not rotate the axle when performing this check and do not use the fasteners during this check it will bend the parts closing the gap.
