After a long rest I have started working on my tired TR250 after letting it sit for nearly a decade. I have rebuilt the carbs, had the fuel tank cleaned and sealed, replaced ignition components, replaced the battery, adjusted the valves and squirted a bit of oil into the cylinders. I have also been talking to the car very nicely and promised to never neglect her again. After some deep prayer and hope, I turned the key and she fired in seconds! After fussing with timing and carb sync a bit she idled down to the sound we all love. The one thing I didn't realize was my car had become a smoker during her break from the road. I let her run for a good long while thinking the oil in the cylinders just needed time to burn off. To my sadness she kept right on smokin' away for 30 plus minutes when we were paid a visit from our local fire department! No joke! Since then I have started her up a few more times (after alerting my nevous neighbor) and she is at least a three pack a day smoker. The only other thing I have noticed is low, very low vacuum pressure and at the retard unit at idle and I am fairly certain that there are no vacuum leaks. Is it possible to set the timing incorrectly and result in a horribly rich mixture? For example: if the timing is set with the vacuum lines connected (which I know is wrong)will fuel mixture be effected? My carbs are the ones without adjustable needles. Or am I wishfully thinking and my engine is toast. When I last drove the car she was definetly a none smoker. Stuck rings? Fried valve(s)? It is very difficult to desern the smoke colour for additional clues. Besides the smoke, she doesn't run half bad. Can someone clue me in on the timing fuel mixture relationship? /ubbthreads/images/graemlins/confused.gif
