1978 MGB with a rebuilt engine and about 400 miles on it will not pass smog after 3 tests. The carb is pretty lean but the CO2 still does not pass. We can tell it is lean based on the lack of acceleration and pinging. IE: the acceleration was there prior to adjusting and taking it to smog. The smog pump worked when we rebuilt the engine but since its job is pumping outside air into the exhaust prior to the catalytic convertor, how do I know it is pumping enough air? Is there a way to increase the air that is pumped into the exhaust, ie, use the dilutional effect?
Last question, the car has its original catalytic converter. We know it works, because it gets really hot. But would there be an advantage in adding another one to the car to get the smog test passed?
Any other ideas?
Jerry
PS: California car
Any other ideas?
Jerry
PS: California car
PJ
