richberman said:
Of the people who've done the Toyota 5-speed conversion I was wondering:
1)Do I really need a lightened flywheel?
2)Do I need the BJ8 diaphragm type pressure plate or will my BT7 lever type work?
thanks in advance.
rich
Rich ,
I too had considered doing the toyota conversion and i spoke with Pete and he said that some of the parts from my BN7 (and most likely that would include your BT7) WERE NOT COMPATABLE WITH THE SWAP. I think he did say to use a BJ8 fly wheel and pressure plate and I agree with others that it would be best to have the assembly lightened up. What I ended up doing was rebuilding my orginal side shift and it really wasn't very difficult to work on and I only spent around $ 350.00. I replaced one shift fork, the second gear syncronizer, the lay shaft bearings,detent balls and springs, all the gaskets. Make sure to use thread sealer on the bolts that enter through the case to oil. Shifts great now.
