Smiths Speedo
TR674
Hello all
this has probably been posted many times before, but can anyone shed some light on my speedo guage? Both my tacho and speedo indicators 'jump' around quite a lot. The tacho cable recently broke and the replacement cable stopped the jumping indicator. I greased the speedo cable and the jumping has reduced, but not by much. Is there something worn within the guage? Can they be serviced, or should I just live with it?
Regards
Craig
DNK
A good cause is a break in the speedo as well.There has been discussions and fixes were called out. I hope I spoke the correct Fix.
Geo Hahn
If greasing the cable reduced the jumping of the speedo then I would suspect that a new cable will be even more helpful. The cable can bind apart from a lack of lube (kink in the cable, damage to the housing, etc).
The jumping can also be a result of someone attempting to lube the speedo. Any more than a very very small amount of very light lube applied to a couple of specific spots can eventually find it's way to the drag cup and cause erratic action between the spinning magnet and the cup.
Geo Hahn
[ QUOTE ]
[/ QUOTE ]
DNK -- You're a 'Jedi Warrior' but that sounded more like Yoda to me /ubbthreads/images/graemlins/tongue.gif??
TR674
TR674
Thanks Geo.
I did notice a slight resistence when pushing the inner cable back in. The last 4 inches felt tight, at the diff end, i assumed the new grease would fix this. The speedo cable looks new though. I'll replace it before I pull the guage appart.
Regards
Craig
DNK
Craig- If my fuzzy memory serves me correctly, the binding usually is at the Trans end. By the way don't touch the diff,it's along way from the problem.
I know that was a brain typo, common here too!! /ubbthreads/images/graemlins/cool.gif /ubbthreads/images/graemlins/laugh.gif
TR674
TR674
DNK
yes, it's late Friday afternoon and almost beer'o'clock.
I'll be thinking alot clearer in a few hours time....
Regards
Craig
KVH
I took my Smiths Speedo into a local shop because it was jumping all around, too. It wasn't the cable, and new one I put in made no difference. There was no issue with the connection at the transmission.
I was told the problem was strictly internal to the speedometer. I was also told to be careful with cable grease. They said you have to keep the grease away from the unit itself.
Anyway, the point is that there wasn't any way I could've fixed it myself. Good luck.
P.S. They fixed it for $50.
G
[ QUOTE ]
[/ QUOTE ]
Same here. My speedometer jumped around to the point that it was almost useless. Tried changing cables, cable sheath, etc. Finally sent it to Nisonger when I had to have it calibrated because of addition of overdrive and tire size change. It is now working flawlessly, and looks brand new. This would be the ultimate fix. Lots of plastic parts in the instruments, they don't last forever.
jeff3113
I had mine repaired for the same symptoms in 2004. It lasted about 500 miles. Seems now it is toasted. The speedo cable apparently had been occilating while spinning and had worn out the brass worm gear inside the speedo. Being taken apart back at the repair shop, it was full of brass shavings. I was NOT going to put more $$ into it. Period.
For all those interested in keeping things stock...stop reading from this point on... /ubbthreads/images/graemlins/grin.gif Out side of the gearing I figure speedometers work pretty much the same.
I've decided to replace the internals and use the TR faceplate for whatever might work. Well,,it might be hard to believe, but a Honda CB750 speedo is the likely donor. The odometer openings line up almost perfectly - and it has the trip odometer. Faceplate screw holes the same. The back Smiths housing needs to be cut a bit. The 700r4 transmission has several gearing options to match the speedo internals.
Actually, nothing too scary since I am using an electronic tachometer for the V8 - using the stock TR6 faceplate. The aftermarket versions out there were too different for my taste (and budget).
...another engineering project soon to be launched.... /ubbthreads/images/graemlins/laugh.gif
I may need to christen this thing a "Franken-6" when it's all said and done
jeff
G help id this smiths speedo Other Cars 2
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
nichola TR6 Smiths volt gauge needle barely moves Triumph 25
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
angelfj1 TR2/3/3A Restoring Smiths heaters as fitted to a 1959 Triumph TR-3A Triumph 4
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
T TR2/3/3A Smiths Heater Checkout Triumph 7
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
J Help with Smiths heater. Other British Cars 4
W 100-4 Smiths heater clips Austin Healey 11
K Smiths Electric Temperature Gauge Triumph 7
Tinkerman Jaeger and Smiths Speedometers Triumph 5
luke44 TR2/3/3A TR3 Smiths Heater Plate Triumph 3
RJS Smiths PCV Valve Differences? Triumph 2
M Smiths Fuel Tank Sending Unit Austin Healey 3
R smiths guage problem- need advice Austin Healey 4
M Smiths fuel tank sending unit Triumph 1
C Smiths or Lucas Gauge? Triumph 8
58Custom New! Schematic for Smiths RVI tachometer Spridgets 9
Tinkerman Smiths Heater Lables Triumph 11
angelfj1 New WIKI regarding Smiths Heaters Triumph 0
angelfj1 Link to Smiths Heater Article Now Fixed Triumph 0
angelfj1 How To Restore a Smiths Heater Restoration & Tools 8
angelfj1 Smiths Heater - Completely Restored Triumph 3
angelfj1 Weekend Project- Smiths Heater Restoration Triumph 13
amcboy A little about Smiths gauges... Triumph 31
angelfj1 Smiths heater Parts Triumph 8
tosoutherncars NOS Smiths gauges: Bugeye? Spridgets 4
B Smiths Dual Guage Repair Spridgets 13
wkilleffer MGB Question about the Smiths temp. gauge- 74 MGB MG 19
coldplugs Be thankful [Re Lucas, Smiths, SU, et al Other British Cars 10
dklawson Needed - 4" Chrome Smiths Bezel Triumph 4
A Brighter Smiths Instrument Bulbs --- Any ideas? Austin Healey 25
S Which Smiths heater in '65 AC Cobra? Other British Cars 5
T T-Series smiths or arnolt heater installation in an MGTD MG 1
Kira Smiths Clocks Pre 1950 Other British Cars 6
G Tacho Smiths RVI2401/00EN needed MG 0
G SMITHS SPEEDOMETERS MG 2
J Smiths Tachometer MG 8
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
