Well, tonight I finished re-installing the pistons in my Spitfire engine, after installing new AE rings! For some reason, gaps in the rings that were installed before were way too wide (double specs) This is what I "suspect" may have been why I was getting too much crank case pressure, and thus oil out the back end (even with a brand new rear seal). Before I put the motor back in, I have to decide how much detailing I want to do on the firewall and frame, front end, etc. first
A heat gun is plenty (but still can do some damage if you're not careful). With it and a fairly dull scraper, you'll likely remove most of the coating without scratching the surface underneath. It's possible that you'll then be able to do final cleanup with a solvent and not have to do anything more unless you find spots of rust or damaged paint.
