tntriumph59
Member
Hey guys!
Finally got the 59 tr3a up and running yesterday. Once I got everything tuned in we took it for a drive. The clutch is very hard to press to the floor and when pressed to the floor it takes some time to return to its normal position. This is causing some trouble with getting the car in and out of gear. It looks like the hose from the slave cylinder is pretty shot. My plan is to drain the fluid, replace the hose, and bleed the system.
Do you guys think this will take care of the problem, or does this sound like a slave cylinder issue?
I appreciate your guys help.
Andrew
Andrew
