Recently rebuilt the MC on my 61 AH Sprite, brake side working but clutch is not; believe the problem is not the MC but the slave cylinder(sc). The problem is that when I pedal down on the clutch there is no resistance (did bleed clutch, fluid goes to clutch but pushrod does not move??)
Would someone confirm for me where the hydralic line screws into the sc, that is, at very end of sc or the other port located midway (logic would seem to think that the hydralic line goes in at the end but I've been told otherwise)?
Also, what role does the "spring" have inside the sc and how do you remove the spring for inspection, or how do you know that it needs replacement? Much appreciated...Irish /ubbthreads/images/graemlins/cool.gif
