SKF Speedi-sleeve p/n for tailend of transmission?
TuffTR250
Can someone tell me the SKF part number for the Speedi-sleeve that will fit the flange on the rear end extension of a TR3/TR4 transmission? Thanks!
I've replaced the transmission rear extension oil seal, but the flange piece has a little bit of a groove in it so I thought I'd better fix that before I put it back on.
Regards,
Bob
Think it might be this:
NATIONAL Part # 99168 More Information About this Part Redi-Sleeve; Shaft Size Min=1.684", Shaft Size Max=1.69", Width=0.563", Overall Width=0.688", Flange Outer Diameter=1.906",
That's what Rockauto lists for a TR6 gearbox, should work as well for TR3/4 but you'd want to measure I think to make sure.
Great! Thanks for the quick reply!
p.s. I checked at Moss web site and TR3 thru TR6 all have the same p/n for the flange, so I think a Speedi-sleeve for TR6 would fit TR3/TR4.
Regards,
Bob
Thanks again Randy! I went ahead and ordered the SKF p/n 99168 from RockAuto. It had almost the exact same specs as the National and I've had good luck with SKF sleeves in the past. I measured my flange and it measured within the specs of both National and SKF sleeve p/n's 99168.
Regards,
Bob
