Silly question-- Where do the washer squirters go?
58Custom
My '69 was originally equipped with windshield washers. But I can not find the squirters. It's possible that a PO removed them and filled the holes (like a PO did to the trunk badge), but I kinda want to reinstall them.
I like everything to work, so this is gonna bug me if I don't fix it. A bit obsessive, but it's fun.
First look up underneeth and see where the holes were filled.
Re: Silly question-- Where do the washer squirters
ecurie_ecosse said:
The cowl is the most likely place.
Stuart. :cheers:
yes cowl - you should look down and see the holes for the wipers. there should be two smaller holes - maybe a foot apart from each other closer to the hood - does that make sense - should be obvious
Gotta install that setup next...does anybody have a photo of how the lines go in the engine compartment of an early car...from the firewall up to the washer bottle in the front of the driver corner of the engine comaprtment?
Yep, I forgot to take photos of mine!
Tony, here are two ugly pics but it shows the tubing running along the master-cylinder and running just to the left of the hood hanger to the front
Mark
Thanks, Mark - do you have one showing where it comes out the firewall?
Small, very small hole with a rubber gromet just above the wiper motor and to the side of where it goes through the fire wall.
Yes, hay Tony use this pic.
Oh, man, is that good! Hopefully, there's no changes from the Bugeye to the MkI Midget!
No changes Tony.
Well, that's one of the best tools I've seen yet - answered many of my questions!!
I think we have all used it over the years. No clue where it came from.
