Newkie
Hey,
In a prior post, a couple of you mentioned being able to replace the sills without cutting the rocker panels out.
Can you or someone go into detail on that process from past experience or knowledge. The sills are only bad in the first 18 inches on drivers side, and the last 9 inches on the other. Or, would you do the whole cut out to make sure the rockers get the proper attention?
I would appreciate any info on this topic, because beside that, the car(73'B) is really solid.
Thanks
Newkie
Thanks
Newkie
