Hi all,
Just did a Jag XKE dot 5 complete flush last Thursday. Its been 5 years since the last flush the owner told me . Fluid was blackish, has S/S lines throughout and Low Pressure lines renewed last flush. Another disadvantage to DOT 5 is it does not have the lubricating capabilities as a Glycol base DOT 3/4 and seals will wear out faster in your M/C and slave units. In my earlier post what I mean in the sentence about silicone just carrying water is true, it is not hygroscopic meaning water absorbing so any moisture that enters the system ( however it can get in ) will just travel and go to the lowest point or get stuck seals and over time if the car is not used will cause rusting to the ferrous cylinders. What I am trying to promote here is flush your systems regularly DOT 3/4 and DOT 5 ! Yes storage has a lot to do with how moisture can get into a system, climates the car is living in ect. , all systems are vented to the atmosphere , thus allowing a certain amount of moisture in . The Jag I replaced all the components in was professionally restored and fluid bottles well marked DOT 5 only. I cannot answer why the entire system was pretty much trashed.
As for the servos it is still a big no to use DOT 5, see pic posted on instructions, Harley Davidson is now not recommending use of DOT 5 as well as Wagner Lockheed.
Again this is from my experience ( my day job) yes it can be used and has been for many years but these are problems that keep popping up and now manufacturing companies are backing down from its use. Im not here to start a pros and cons thread, just google the info yourself.
Carroll
Top Down Restorations Inc.
