MGTF1250Dave
Aloha All,
I just completed a brake system overhaul on my TR3A. The rebuild kits included a tube of grease, either redish in color or a white color. Ths instructions with the kits said to use this grease as an assembly lube with the rubber seals. I have always used brake fluid as assembly lube on wheel or master cylinders, so I didn't use the grease. At a recent club Tech Session, I was asked about silicon grease used in brake systems. My questions are, what is brake grease and how/where do you use it? is silicon grease and brake grease the same thing? Do you use brake grease or brake fluid as an assembly lube?
Safety Fast,
Dave
Safety Fast,
Dave
Hi Guest!
