bighly
Knoledgable ones,
I have not pulled a transmission in 15 years, now I get to re-live a bit of my youth.
I am looking for a recommendation for someone in the SF Bay area who knows AH trannys and ODs very well to help out with my pending repairs/rebuild. I have probably slipped third gear fork or have a broken syncro. OD mechanics also don't work to well.
I have not pulled the thing out yet but understand the procedure as follows.
Day 1. Have a Gunniess and just look at it and put it off another day.
Day 2. Jack way up and place on jackstands.
Support tranny.
Remove tunnel, bulkhead.
Drain. Disconnect clutch linkage, OD, speedo.
Remove starter.
Remove rear most mount, tranny mount.
Disconnect from engine
Ease back (may requre slightly elevating rear of engine)
I also understand that I do not have to drain the hydralics.
So I plan to pull it out and if I can find a reputable rebuilder in the SF bay area I'll let them rebuild/fix it.
At this time I also want to add an aftermarket rearseal (any recommended sources?).
Writing this email allows me to procrastinate a bit longer.
Comments suggestions? What am I getting into.
Support tranny.
Remove starter.
