sidescreen aluminum finish
5
57_BN4
What was the original finish on the early (forward sliding pane) side screens please? Were they originally polished then anodised or left natural ali?
Mine are dull un-anodised and are making everything they touch go grey, particularly around the hood where the doors close. I'd like to stop this happening but I'd also like them to look fairly original.
Andy.
John Turney
Anodized like the cockpit trim.
This is the best photo I have: SAM_1289.jpg
57_BN4
Thanks John. Your car looks very nice with the green roof.
What do your side screens have for an opening handle? Mine have rectangles of perspex glued on about 1/2" below the midway point towards the front of the sliding pane but they a bit too home made to be original.
Andy.
John Turney
If you look very carefully, you can see a rectangle of Perspex on the lower front part of the front half in this photo from Anderson & Moment. I made mine like this using 3/8" or 1/2" sq clear plastic. The long side of the rectangle is at the same angle as the front of the rear half.
richberman
So my question is.....what kind of adhesive should be used to glue the little rectangle of plastic to the perspex sidescreen?
57_BN4
Thanks for the reference pic John.
I found a couple of pics a bit further along in the Restoration Guide that show a handle more clearly and it is near vertical. "Original Austin Healey" also has a nice clear pic showing the top of the handle block approximately the same height as the top dome nut so I'm going to go with anywhere around there is ok.
Interesting that the furflex stops at the level of the draught excluder on the car shown in the Resto Guide, I was under the impression it goes all the way up to just below the scuttle seal.
Cheers,
Andy.
Patrick67BJ8
Cheers,
Andy.
I had original plex pcs several years ago and the Handle Block was concave on the two longest sides so that your finger-nails(?) could more easily grip it. I think they were about 1/4", ,250 in thickness. Also, all four sides were polished.
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
Lbp TR2/3/3A Correct Colors for Hoodstick and Sidescreen Mounts? Triumph 12
5 Longbridge sidescreen vs hardtop Austin Healey 16
Simmo Sidescreen Ashtray Triumph 12
NutmegCT TR2/3/3A TR3A sidescreen vinyl seal Triumph 13
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
T Yes, I have too cars. Sidescreen help Triumph 14
JohnnyMead Vendor for Sidescreen Rubber Stuff? Triumph 3
CJD TR2/3/3A TR3 Sidescreen Rebuild Triumph 22
CinneaghTR Let's Play "Name That Part!"-Sidescreen TR Triumph 10
Z Early BN1 Sidescreen Restoration Austin Healey 28
angelfj1 Sidescreen TR's - Body ID Tags Triumph 0
bt7tricarb Tonneau Bar questions ['62 BT7 Sidescreen car] Austin Healey 5
AweMan TR2/3/3A Tr-3 Sidescreen Question Triumph 4
jsneddon Sidescreen TR rear Hub Puller Instructions Triumph 10
YankeeTR Yeah...I know I didn't need another sidescreen TR. Triumph 8
DerekJ Sidescreen renovation Austin Healey 7
txtr3 Top and Sidescreen materials Triumph 3
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
