jvandyke
I'm psyching myself up to drill holes in my body panels to install the side mouldings. PO removed during restoration so no existing holes.
I bought the kit from Moss with a gazillion little bits in it.
Here's the plan.
Last fall I made up plastic strips that fit into the moulding, I epoxied earth magnets to it so I can stick the trim on the car. I was thinking to get them on like that, all lined up nice and purdy, then run painters masking tape along the top and bottom edges of the trim, then pull it off again, leaving a very precise "stripe" where the trim should go. Then I must figure out where the "bolt on" type hardware must pass through the body panel where I can get at the backside to put the nuts on. Then I can rivet the little clips in between. How many of each type and where the holes should go I haven't figured out yet.
Any advice on this greatly appreciated!!
BTW it seems the rear quarter trim pieces have a slight downward curve as they near the taillights, both pieces do it so it seems like they're supposed to?
I was going to go just above the front wheel opening as pictures I've seen seem to show the trim running very close to that, then I'll line the rest up according to fitment.
Here's the plan.
