Hi Guest!
I have a Stebroe side exit on 64 BJ8 , only have the factory heat shield under the car . I have Dynamat all up the footbox and full length the tunnel . The dynamat ends at the seat rails . Heat is not an issue and the paintwork just gets slightly dirty at the exit point , no paint damage .
This pic is pre-restoration .
John,
Yes, same mufflers.... just moved/extended the pipes. It sounds easy if you say if fast. But, with the Putzke Bilstein shock kit and radius control arms it was a bit of a challenge. I'd be happy to share pics of the project if you're interested. It would have been easier to do during the build than a year later. That said, I'm very happy with the change. Still has a great sound, just turned the volume down... it may be a bit deeper tone due to the extra length. At cruising speeds you can now hear the radio or talk.... wife likes it much better.
Cheers,
Steve
John,
Cheers,
Steve
