After many hours of frustration - it's time to ask for help. I searched "shut pillar" and found some good info, but mostly for later Healeys and not exactly what I am looking for. I had a good fit - front fender - door - rocker - rear fender. Then i installed the latch pieces and found the shut pillar angle was off on the body of the car. Cut the pillar off - re-welded and all looked good. Then i got the finisher pieces and saw they were embossed which completely changes the angle of the latch mechanism again. What i don't understand is that the shut pillar is recessed and the finishing plate is raised (and angled) creating a void between the two (i know the 1/8 inch aluminum finishing plate was not meant to take the clamp pressure created by tightening the 4 screws let alone the slamming of a car door). Also, the angle of the raised section of the finishing plate will push the edge of the shut pillar back at least a 1/4 of an inch making the door gap off. Looking for feedback of anyone who has installed the pieces and of course pictures. Thanks in advance for the help.
Hi Guest!
