Shut face finisher-where to purchase a good set???
AUSMHLY
64BJ8 II
OK, so I bought a set of the shut face finishers from British Victoria a while ago. The body shop installed them and they just don't fit right. The passenger door side is too short, and moving it up, will ruin the fit at the bottom. Problem with the driver side fit too.
The ones from BV were thinner than original and certainly not correct in size.
After talking it over with the interior guy tonight, we decided that I should get another set. But where, from whom?
Keoke
[ QUOTE ]
64BJ8 II
[/ QUOTE ]
------? ? ? ? ? ? ? --Keoke- /ubbthreads/images/graemlins/cowboy.gif
Lin
Roger,
I got new ones from Gary Hemphill at Hemphill's Healey Haven. They did require trimming, but they are longer than required, not shorter. They worked for me.
Lin
1960 BT7 in restoration
1959 Bugeye
sunkissedhealey
Re: Shut face finisher-where to purchase a good se
Hemphill's Healey Haven usually get things right. I'm calling them today about shut pillar seals. I don't think that I've ever had to return a part that I've ordered from them.
Rob
SHG
I bought a set from AHSpares. They were longer and a little off shape as well, and needed to be trimmed. Close, but not quite right.
I fit a set of the VB ones to my car last weekend (put a dent in the Scotch reserve too). All the symptoms you mention except that there was excess material for trimming. Biggest issue I have with them is the shape at the top of the door shut face; doesn't match the contour of the cockpit surround trim. I'll get (digital) pictures "developed" and posted later on...
Who has DECENT windlace for the doors? Twice I've attempted to install the $hit with the aluminum clips (once on a BJ8) and this time I just wound up throwing it away. &*#@*&!!
Keoke
Hi Randy, try Martin Macgregor in Canada for the door excluder material.He advertises on this forum.---Keoke
[ QUOTE ]
[/ QUOTE ]
Thanks, will do. /ubbthreads/images/graemlins/cheers.gif
AUSMHLY
AUSMHLY
The Nocks are on vacation for a week. Healey Surgeons are on vacation to Aug 1st or 2nd week. The Trim panels in my photo that don't fit properly were bought from BV.
Moss told me theirs do not have any cut outs for the screws nor the latch. They are solid. Someone mentioned to me that the ones from the Australia are solid, which I think would be the ones from the Nock's. BV and Surgeons are from AHspares I believe.
Being I am trying to get my car done for my birthday, which is this coming Thursday, I ordered the ones from Moss. Returnable if not a good fit. I'll let you know the quality of those when I get them Monday.
It's been two years restoring my car. Now it's coming down to the wire. It certainly would be a special birthday memory to have our maiden drive on my 50th. Cheers, Roger
Keoke
Well Roger, it just may be the case that the Moss panels are from Kilmartin I know they do stock some of their products.--Keoke
Lin
Roger,
Your call but why didn't you go with Hemphill's. Gary's worked fine. Holes and cutouts all there.
Lin
1959 Bugey
AUSMHLY
AUSMHLY
Lin,
Because Moss is close to me and always delivers on time, usual 2-3 days for me. Returnable if not happy. And Like Keoke mentioned, I too believe they are Kilmartin pieces. I hear good things about Kilmartin.
Most of them come from AHspares, which seem to have fit issues, and I figured, it's all a crap shoot. So why not try Kilmartin.
Even though the holes are not predrilled, in my case it may be to my advantage. If need be, I can drill new holes instead of using their holes, in order to move the piece where I need it to be, to cover the rivets. Then I will not have predrilled holes with no screws, nor will I have more screws than should be.
Looks good on paper, we'll see what happens when it happens.
Cheers, Roger
John Loftus
Hi Roger,
I bought a set from Moss last year (or was that the year before?) and they were Kilmartin. The outline is larger than the originals so they will be carefully cut down and they do need drilling but that should be fairly easy (especially since I have originals to go by). Without good originals you can use heavy card stock to make some templates and get the outlines and holes in the right place. They will also need some subtle bending to fit the shut pillar better at the top but the aluminum is soft enough to be easily bent.
Cheers,
John
Cutlass
This raises the question of what are the proper number, location and spacing of the screws that hold the shut face and rocker finishers? I've replaced the rockers, and the original finishers were not on the car. This stage is a bit far off for me, but since the topic is on the front burner here, thought I'd ask now. Thanks.
Keoke
Hey John, you know what helps that subtle bending at the top and the radius bend.Get a short piece of broom handle and a hammer and tap the ali lightly into place.---Keoke- /ubbthreads/images/graemlins/yesnod.gif
SHG
[ QUOTE ]
[/ QUOTE ]
That's how I did it. But I still have to wonder why it didn't fit in the first place, the recurring theme in repro parts. Some of these parts are pretty darn expensive relative to what they are, and you figure they ought to be made right in the first place. I can't tell you how many parts I've bought from Moss or VB that are just slightly off, either in fit or appearance. Why? I really don't get it.
Keoke
Well SHG , maybe its just cuz these car were originaly built using a big hammer and most of them are still slightly off.---Keoke- /ubbthreads/images/graemlins/cowboy.gif
SHG
Ah, the big hammer theory. "Don't blame us, blame Don Healey."
Keoke
[ QUOTE ]
[/ QUOTE ]
/ubbthreads/images/graemlins/savewave.gif
Nope,Prolly more like Roger's fault.You know he never used a Torque wrench either---Keoke- /ubbthreads/images/graemlins/laugh.gif
P Question about BJ7 Shut Face Finisher Fit Austin Healey 3
B Shut Face Finisher Austin Healey 1
bighealeysource Shut face finisher polishing ? Austin Healey 8
AUSMHLY Shut face finisher, placement Austin Healey 19
J What's the Secret- Keeping New Aluminun Shut Face Finishers Looking New? Austin Healey 7
B aluninun shut face pillar cover on BJ8 Austin Healey 8
bighealeysource How to clean aluminum shut face finishers ? Austin Healey 9
bighealeysource Best way to remove aluminum smudge from shut face Austin Healey 1
bighealeysource Best way to trim shut face finishers Austin Healey 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
J Gas pump auto shut off question Austin Healey 2
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
SherpaPilot TR6 Engine Will Not Shut-Down Triumph 4
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
M TR2/3/3A Car won't shut off with generator connected Triumph 6
AH100M BN2 Door Shut Pillar Trim Austin Healey 2
P Overheating after shut down & recommendation on thermostat Austin Healey 3
T seat Belt Buzzer Wont shut off Triumph 5
B Engine Dieseling a Bit at Shut Down Austin Healey 12
N AH100-4 shut panel replacement Austin Healey 6
R Brake lights won't shut off Triumph 8
B Shouldn't the fuel pump on a 3000 MKII shut off... Austin Healey 3
brgrmyster TR6 TR6 Overheating after being shut down Triumph 36
Superwrench Door shut gusset Austin Healey 3
L Doors slam shut Austin Healey 16
N Aluminium facing on sills and shut pillar, BJ8 Austin Healey 7
M Shut Pillar installation - 62 BT7 Austin Healey 3
Jim_Gruber Picture of Shut panel behind front wheel Spridgets 9
JohnnyMead Modern Fuel Shut-off for Our TRs? Triumph 12
toysrrus TR2/3/3A TR2 / 3 Feul Shut-Off Vlave on Ebay! Triumph 5
K TR2/3/3A TR3 Gas Line Shut-off Valve Triumph 12
livinginthepast BE horn never worked. Now it won't shut up Spridgets 12
dklawson Bad Economy Forces Crane Cams to Shut Down Spridgets 7
M Driver Door Just Won't Shut Tightly Spridgets 2
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
GregW Measurement for shut pillar top piece BJ7 or BJ8 Austin Healey 6
hondo402000 Starter problem and motor wont shut down Triumph 22
Bob Claffie Trunk shut off switch Austin Healey 8
R BJ-7 Shut piller seals? Austin Healey 14
G Shut pillar placement bj8 Austin Healey 9
H How Does Battery Cable Connect to Shut Off Switch? Austin Healey 21
RSMTR8 Wedge TR8 Shut Off Triumph 6
71tr fuel line shut off valve Triumph 16
S BJ7 Shut Panel Adjustment Austin Healey 9
George Zeck Fuel Pump / Rough Shut Off ..... Spridgets 2
B TR6 Thrust face repair Triumph 1
John Turney Custom Face Masks Austin Healey 15
