Motorcycle shops can often bore TR liners...TR3driver said:True, but I have put engines back together with the cylinders pretty badly worn, and they still run fine. They might use more oil, and will need attention again somewhat sooner than if you bore the cylinders, but we're talking like 50,000 miles instead of 100,000 miles.
Mike, there is a growing movement to rebore old liners rather than just replacing them. It does take some special equipment to do it right, and most machine shops won't have the equipment, hence it's usually simpler to replace the liners (on the wet-liner TRactor motor used on TR2-4A). But you can save a few $$ by finding someone with the right equipment (not to mention knowing that the metal in the liners isn't old beer cans). Try Joe Alexander or Ted Schumacher. If they don't have it, they'll know who does.
If the engine is is rough shape it would be advisable to pull it. Back in the day we seldom, if ever, pulled an engine and did a full bore remanufacturng on 'em. Always done in-frame unless the block was damaged...we even had a local machine shop bore the cylinders and grind the cranks in-chassis (if possible)!RonMacPherson said:Yankee TR,
Concern I have with an in frame is the rear main seal.Tr6 rear mains do get old, hard and leak. And when he gets the flywheel off, it is very simple matter to have a machine shop lighten it for relatively little money.
I am answering his question on the premise that he wants to overhaul(i.e., rebuild) the engine. Not just patch it.
So, I still recommend pull it, tear it down to the best of his comfortableness, take the block and pieces to a machine shop for measuring and work. Have the machine shop reinstall any parts he is uncomfortable doing and he should be able to reassemble the rest.
That's exactly the way ... but I made a brass-faced drift to avoid cracking the liners. Didn't matter as I was going to 87mm anyway (bought a used set of 87s from a racer that went even larger), but saved the originals JIC.TR6BILL said:I ended up using a maul and large drift to coax them out, cracked two of them. Perhaps I could have used a different technique.
<snip>
The point is, don't see how one could remove liners with the engine in the car.
TR6BILL said:Anyway, the Vicky Brit page listed above shows "Liners" for the TR6 engine. Most guys that have the bore increased on their TR6 engines simply have them bored. I had so much slap that the machine shop bored and used liners or sleeves. Usually, most guys don't go with sleeves on these engines when boring. Someone told me once that some of the 6 cylinder blocks were sleeved from the factory. We used AE pistons, 20 over.
