Rob Glasgow
Several months ago, the diaphragm in the heater control valve gave up after 46 years of reliable service. I replaced the valve, repainted the heater box and installed new heater hoses. On the next drive, I put my hand up under the dash to see if I could feel any leaks around the valve. No leaks-a good thing. But what I discovered was that the incoming heater hose was extremely hot. Then it dawned on me. 1. The hose is full of water at engine temperature (180 deg.). 2. The exposed 12 inches of hose inside the cockpit makes a wonderful supplementary heater – fine for winter driving but not really a good thing when the summer temperature outside is 100 degrees. Lord knows a Healey doesn’t need more heat in the summer.
It should have been obvious… that’s why they put that shut off petcock on the side of the engine. After 43 years of ownership, I now know you are suppose to shut off the flow to the heater during the hot weather. After I closed it, the hose is now just cockpit warm, not engine hot.
Live and learn.
Rob
Live and learn.
Rob
Hi Guest!
