Hondo Hernandez
I think John Loftus recommende I should come here for advice. Removed rt front shock and the welded nuts inside mounting box are broken off. Suggested solution is to saw, grind, cut old box off and weld replacement one on. Does anyone have advice on best way to do this. Can't move the Healey now - it's on blocks and in front of the boat so can't go fishing - bad !!!!! Could I use a reciprocating saw to cut off the old, then grind to smooth surface then somehow weld, maybe mig welder, the replacement. See....I don't know what I'm doing. Appreciate any advice you provide. Thanks in advance.
