General Tech Shock oil
Raymond
Hi
What does everyone use for Armstrong shock oil??
NutmegCT
Each to his own, but here's a recommended list:
20W motorcycle/ATV fork oil, hydraulic ram oil (for snowplows, etc; or from farm stores, AWE68 oil), hydraulic jack oil, or straight 20W engine oil
Tom M.
Mineral oil. Non-petroleum, same as Rolls.
twas_brillig
I'm cleaning out the garage a bit, and found half a dozen or so 500 ml bottles of Castrol Automatic TQ-F transmission oil with AH SPares part number MSC130. AH Spares has nothing corresponding to this part number but I checked my back orders and found that it was sold as SHOCK ABSORBER FLUID-CASTROL and I'd bought the stuff in May 2006. AH Spares still sells the same Castrol TG-F as shock oil, but different packaging and part number. Our 3000 has Fahrpass Bilsteins; touch wood both BEs will be running this summer and they have Armstrongs, but I sure have plenty of fluid. Doug
AUSMHLY Rear Lever shock, add oil? Austin Healey 28
wkilleffer MGB Armstrong shock oil- 20W oil? MG 5
K TR2/3/3A Harley Davidson shock oil for Lever shocks? Triumph 3
L Oil under left front shock Austin Healey 7
Sarastro What do you use for shock oil? MG 17
Jeepster Shock absorbers oil level. Austin Healey 6
S TR2/3/3A tr3 Shock oil leaking Triumph 2
L Oil for Shock Absorbers Austin Healey 1
BOBBYR Shock Oil????? Austin Healey 3
J lever shock oil Triumph 7
M damper [shock] oil MG 6
Wana Shock Absorber Oil Level [was "Oh No!"] Austin Healey 12
PAUL161 Tony, Doc, Question on shock oil type MG 11
Guinn Shock oil MG 4
S Shock Oil Restoration & Tools 10
Boink Ugly Shock Failure Spridgets 3
H Shock absorber conversion Austin Healey 3
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
C MGA Shock fluid MG 13
AH67AH Broken Shock Mounts Austin Healey 23
H Rear Shock Removal Austin Healey 5
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
J Thread Locker on Shock Bolts? Austin Healey 19
M e-type siries 1.5 shock abosorbers Jaguar 3
O Shock Absorber maintenance Spridgets 4
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
trotti Shock mount problems Austin Healey 9
S TR2/3/3A rear shock arms and links Triumph 4
TRopic6 For Sale Used Armstrong Rear Shock Set; AH Sprite / MG Midget, 1958-70 Spridgets Classified 0
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
John Turney Left Rear Shock Mount Austin Healey 5
R Shock Absorber Austin Healey 0
Griz Shock failure Austin Healey 4
S TR6 TR6 shock links Triumph 10
G TR4/4A Front Shock Install Triumph 14
G BJ-7 Rear Shock Link Austin Healey 2
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
T TR2/3/3A How important are matching rear shock links? Triumph 9
maxwedge5281 front shock absorber mounting Austin Healey 3
Sarastro TR4/4A Shock aborber recommendations Triumph 6
T Tube shock conversion BJ8 Austin Healey 6
D TR4/4A stubborn lever shock link Triumph 2
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
