MGA Shock fluid
Coastalman
It has been suggested to me that I can use 20W Antifreeze in my lever shocks. Does anyone have any experience trying this? Also, STP has been suggested. Any advice is welcome. Thanks, Charlie
Mickey Richaud
Hey, Charlie - long time, no post!
Never heard of either - one sounds too thin, and the STP sounds too thick. I've used motorcycle fork oil with good results. Others will most likely chime in here shortly.
:cheers:
Mickey
C
Coastalman
Hi Mickey! Yes, I have been low key. Last week I brought home a very nice 1962 MGA and am fixing up little neglected items on the car. I'll post some pictures when I am a bit further along.
Mickey Richaud
Good deal! Love the A's lines.
JPSmit
another vote here for shock fluid. (and getting rebuilt shocks from Peter at Worldwide)
Platinum
Either the motorcycle fork oil or mineral oil. The fork tube oil is a bit lighter.
Scargo
Back when Moby Dick was a minnow, I used Castrol R. It was mineral based in lieu of petroleum based, making it compatible with the seals. It was either 20 or 30wt.
Mickey Richaud
:iagree:
What Joe said.
C
Coastalman
I took the easy way out and ordered some shock oil from Moss when I was placing some other orders. I'll probably get the Harley shock oil for future needs the next time I go to New Bern, NC. We are way off the beaten path here so It is usually easier to order items than go searching for them. Our county is so rural that we only have two stoplights in the whole county. But we do have the Pamlico Sound and the ICW right here. It's a trade off.
Charlie
Madflyer
Well I guess you got me beat my County has four stop lights I think we have three and a Roundabout. The County seat is and hour away with one but never go there so not sure. Shock oil should be an mineral base for two reasons will not hurt seals and not temp sensitive cycle fork oil works and easy to get most places. Madflyer
barneymg
They are hydraulic shock absorbers, so use hydraulic oil. This is usually 20W mineral oil with anti-foaming agents. Hydraulic jack oil works great, and easily available in small quantities anywhere they sell floor jacks (Harbor Freight) or likely any auto parts store. Think pint or quart bottles,
RJS TR4/4A Lever Shock Fluid Level Triumph 1
stretchit2 Hydraulic Shock Fluid - Bilstein Shock Conversion Austin Healey 6
John_Mc Lever shock fluid Triumph 19
G Checking & filling shock absorber fluid Spridgets 9
T TR4/4A Early TR4 - Lever Shock Absorber Fluid Triumph 2
W shock fluid MG 7
G Right-Side Shock Weeping Oil Austin Healey 1
G Squeaking Armstrong Shock Absorber Austin Healey 7
Celtic 77 General MG Lever shock oil refiller MG 0
M Left shock Spridgets 4
Gliderman8 TR6 Lever shock noise Triumph 18
RJS General TR Lever Shock - HD Shock Valve Triumph 2
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
Boink Ugly Shock Failure Spridgets 3
H Shock absorber conversion Austin Healey 3
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
AH67AH Broken Shock Mounts Austin Healey 23
H Rear Shock Removal Austin Healey 5
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
J Thread Locker on Shock Bolts? Austin Healey 19
AUSMHLY Lever Shock Oil Level Austin Healey 41
M e-type siries 1.5 shock abosorbers Jaguar 3
O Shock Absorber maintenance Spridgets 4
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
trotti Shock mount problems Austin Healey 9
S TR2/3/3A rear shock arms and links Triumph 4
Raymond General Tech Shock oil MG 4
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
John Turney Left Rear Shock Mount Austin Healey 5
R Shock Absorber Austin Healey 0
Griz Shock failure Austin Healey 4
S TR6 TR6 shock links Triumph 10
G TR4/4A Front Shock Install Triumph 14
G BJ-7 Rear Shock Link Austin Healey 2
wkilleffer MGB Armstrong shock oil- 20W oil? MG 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
T TR2/3/3A How important are matching rear shock links? Triumph 9
maxwedge5281 front shock absorber mounting Austin Healey 3
Sarastro TR4/4A Shock aborber recommendations Triumph 6
T Tube shock conversion BJ8 Austin Healey 6
