steveg
A PO shimmed my rear wheel bearings with circular shims between each bearing and its seat in the carrier - perhaps to compensate for the thickness of the paper gasket. Shims were made from beer can aluminum stock.
but true! One side had 2 shims which stayed in place; the other evidently had one, which was chewed up presumably by the bearing spinning. This implies the thickness of 2 beer cans is appropriate.
Has anyone else encountered either the shims or the need for them underneath the bearings?
Is there any kind of wisdom or practice on how far the bearing spacer should be proud of the carrier surface?
