Have a really bad rattle in shift lever. Posted previously and told to replace the nylon busing on the shift lever. Did that (by the way, does that go around the ball or on the tapered shaft above?) and also the screws and spring washers on the lever plate. Everything just as bad. Noticed in a book that there is also a plunger and spring that is supposed to be there which I found is not. When checking the Moss and Vicky Brit websites I found that I can order three of the necessary parts but that the cap, which I assume holds everything in place, is not available. Can anybody tell me where I can get this or what?
