sheet metal question
svtmikey
I'm just curious. Where does everyone get their sheet metal for repairs from? New, scrap, online???
I've been scavenging my from other wrecked cars, but newer cars have thinner metal, is it ok to use thinner metal for a patch?
Thanks
Mikey
tony barnhill
Great Pumpkin - R.I.P
I've found that buying body panels ends up less expensive in the long run than trying to fabricate my own out of sheet metal.
mccalebr
Mikey,
Some of the builder's superstores (Lowes and Home Depot in my area) carry shapes and sheet stock in both cold rolled steel and aluminum; gauge selection is not the best. The price is HIGH...gold would probably be cheaper...but is too soft. :smile:
If you need a lot, check with a local sheet metal shop; they will usually sell you what you need.
I've not purchased from the on-line sellers; the initial price is usually better, but the shipping costs eat you up.
Like Tony, I buy most of the stock replacement panels I need from the usual suspects, but there are a few items that are not available, like the "B" posts on the Spridget, or the custom work you might want to do. For example, I fabricated a new recessed pan for a Tilton pedal box that's going into my '62 Sprite just this last week. It's from sheet stock (16 gauge) from Lowes.
Ray
prometalshop
Hi Mikey
Shopping for used metal from newer cars would not be the best choice and create more work for you than new sheet or even a repo panel. New metal is is a high strength low alloy steel and some what thinner. Check with your local steel mills or even local fab shops. If you buy new your best choice is 19 gauge cold roll 1008 series if not 20 gauge of the same like and kind. 1008 is most suitable for bending shaping and welding with the least of difficulty. If you can't get 1008 try to get no more than 1015, this has a bit more carbon but still not enough to make it hard to shape.
The last two numbers are the percentage of carbon and at 15% or less the panel will be less hard.
I hope this helps. :smile:
svtmikey
svtmikey
Yes, I have also been using replacement panels as well, but there are some items I couldn't get. I was sure what guage of metal to get so the tip about the 19 guage cold roll 1008 is a good one.
Thanks guys!
Mikey
merlinron
go to a heating and airconditioning shop. they usually will have a supply of 14 to 20 ga. sheet for making ductwork and brackets. you will want to ask for "black iron" that is the trade name for sheet stock that is not galvanised. it's dirt cheep there as compared to the big box stores.
Busted knuckles TR2/3/3A Sheet metal question, Triumph 5
Popeye Sheet metal question from a rookie Restoration & Tools 5
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
D Made a sheet metal break. Restoration & Tools 5
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
N Spridget sheet metal Spridgets Classified 0
J For Sale Triumph TR 2/3MISC sheet metal parts Triumph Classifieds 1
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
T TR2/3/3A TR3A Sheet Metal Piece Needed Triumph 2
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
Scot1966 TR6 TR6 sheet metal Triumph 3
doc50 Best Method to weld sheet metal repair panels in... Triumph 10
D austin healey sheet metal Austin Healey 2
M sheet metal thickness Spridgets 3
M New sheet metal trades Spridgets 0
R 100-4 sheet metal Austin Healey 1
Michael Oritt Sheet metal for cockpit Racing 4
W restoring a BN2 - need advice on sheet metal Austin Healey 10
P BUGEYE--sheet metal thickness? Spridgets 6
S Sheet metal Austin Healey 14
T Sheet metal brake - must or just nice to have? Triumph 13
P interior sheet metal removal/replacement Austin Healey 21
vette Floorboard Sheet Metal Position Austin Healey 7
beaulieu drilling out sheet metal spot welds ? Restoration & Tools 11
A Moss vs Victoria British sheet metal parts Austin Healey 4
S Welding sheet metal Triumph 17
WALTER Sheet metal next to radiator Spridgets 1
T What sheet metal gauge are Triumphs made of Triumph 11
JPSmit Sheet Metal request Spridgets 5
eschneider homebuilt / economy sheet metal press brakes? Restoration & Tools 0
T What do you guys use to cut floor pan sheet metal? Triumph 7
Darwin Sheet metal gauge. Triumph 4
C Kilmartin Sheet Metal parts availability Austin Healey 7
N What type and gage of sheet metal for rust repairs Triumph 1
G Bonding Sheet Metal ? Restoration & Tools 4
B sheet metal brake Restoration & Tools 2
P Sheet metal items Jaguar 4
J TR 4 Norris Cam 342S Spec Sheet Racing 1
J Got my Heritage certificate but nothing new came on the sheet British Motor Corp 2
Triumph_TR4_Girl Log-Sheet For Renovation Project Triumph 9
Tinkerman 1975 MOSS price sheet Triumph 9
R BL US Competition Dept. sheet Austin Healey 2
D Build Sheet Changes Triumph 15
bigbadbluetr6 TR6 TR6 build sheet Triumph 27
J MG Inspection Sheet MG 4
S build sheet MG 2
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
