pkmh
Never realized just how bad all the pieces were to my sway bar assembly. Even after using generous amounts of PB Blaster and working the fasteners slowly, etc., one of the bolts I attempted to remove from the bush strap to the chassis simply sheared off.
I believe one way to remove the sheared portion is to first drill a small hole in the center of the sheared portion and then use a type of tap to either screw the threaded remains all the way into the chassis or reverse it by continuing to unscrew it out.
I've never had this problem (just lucky I guess), and if there is a better way or other details I should know, then I would much appreciate any advice offered.
Thanks for whatever can be offered!
Paul
BJ8
Paul
BJ8
Hi Guest!
