jjbunn said:Yeh, maybe I should give these problems at least a day of my own solution attempts before I post here and waste everyone's time /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
jjbunn said:The sheared bolt is removed! I could get access via the wheel well to the other side, and simply put a new nut on, tightened it against the other nut, then wound the whole thing out.
Thanks for all the advice, and again to PB Blaster, which as far as I am concerned is a life saver.
Wow, I sound like a PB Blaster commercial!
2wrench said:jjbunn said:The sheared bolt is removed! I could get access via the wheel well to the other side, and simply put a new nut on, tightened it against the other nut, then wound the whole thing out.
And just in time, too, because I was gonna say that
maybe you could buy a reciprocating saw; cut the fender
off; take it to a machine shop and have them drill it out
fer ya.....wait....I wasn't done;
then buy a cheap welding set; read from Wiley's Welding,
Class 101 (out of print but can be found on the net
somewhere), review chapter 2 with special attention
to Figs 1.6 through 4.8; come back to the shop; reweld
what you cut off --- wait, I ain't done....
Then, reviewing sections 6.9 of Top Coaters Guild catalog --and get the Green version only, cause the blue one
really sucks... they took out the side photos... and
then repaint and your done. No sweat. I did this thing
last year when......
jjbunn said:And I suppose I would have to re-sleeve all the reciprocating fulcrum bushings with burnished brass rollers (sintered to Clough hardness, naturally), attach new thrust washers to the pinion slave while maintaining constant tension on the sun gear carrier so preventing it from fouling the grommets in the pin bearings on the vacuum nozzle's flange, which would cause a loss of fluid through the plenum chamber orifice?
Bugeye58 said:Julian, just be thankful you don't have to change the lower grunnion banjos! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Jeff
TR3driver said:Or to replace the Kuhneutson Valve
