Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Can anyone tell me the size of the shear bolts used in the '78 Spitfire steering column lock/ignition switch? Is there a reference somewhere that has various nut/bolt sizes? Tks Harve
I don't know of a list of bolt sizes that covers everything. Often you can figure it out from the part number. Have a look at this page from the Canley Classics web site. Click on 'Fasteners'.
As far as the steering column and ignition lock are concerned, they don't follow that naming convention. The part numbers are 152597 (ignition) and UKC7070 (steering column). They are fairly expensive, but they can be replaced with standard bolts.
The steering column bolt size is 1/4"x3", 28-pitch. Only the last 3/4" of the bolt needs to be threaded.
The ignition bolts can be replaced with cap-screws. Easier to install than hex bolts I found. They are 5/16"x3/4" and they are 18-pitch thread.
