There's a hige variety of Alternators and they have different wiring criteria. Did you use a kit from a vendor?richberman said:Randy Forbes said:Big Step, Rich; you're on your way.
The only Healey I ever worked on (Patricia Dewitt's BJ8, circa 1978... you always remember the bad ones...) that wouldn't shut off had the horn wire inside the steering column melted/shorted to the turn signal feed (keeping it hot all the time). That car, still with its original generator, could be shut off via the battery cut-off switch.
Yours has got to relate back to the alternator conversion. I have the MSD too, wired as per their instructions for a point-trigger (also negative ground) and do not have any run on issues.
But still, <span style="text-decoration: underline">congratulations</span>, and say HI to Bob for me!
No steering harness on the car yet. The alternator conversion was confusing. I had three different diagrams and all were different. See my final pics and please comment if you see something off. I gutted the voltage regular and used it for connections only.
thanks,
rich
