NutmegCT said:
As he has *new* wire wheels, is there a possibility that those wheels and tires still need balancing and spoke tuning?
Yes, especially if the tires weren't balanced properly. The majority of tire shops don't have the equipment to balance them properly.
https://www.mossmotors.com/SiteGraphics/Pages/balance_wire_wheels.html
And even new wire wheels can need some attention to keep them running true. The factory trues them, of course, but they should be re-trued after a few hundred miles.
https://www.hendrixwirewheel.com/wirewheels.html
It is also quite possible to get brand-new tires that are defective and do not roll true under load.
I have removed a TR3A driveshaft without pulling the tunnel, but it was a long time ago and all I remember for sure was that it was a hassle. However, one way to check the balance while on the car is to wrap a big worm-screw type hose clamp around the shaft and see if that makes the problem better or worse. The screw acts as a balancing weight. Then try it again with the screw located at each 90 degrees around the shaft. If the shaft was balanced to begin with, it will be equally worse at each location (or at least no better). But if you find a "sweet spot" where the vibration goes down, the shaft was out of balance.
The hose clamp is actually a reasonably permanent solution (and you can add a second one if necessary).
Another point is that vibration caused by an out-of-balance drive shaft will be substantially higher frequency than that caused by bent wheels. The driveshaft turns roughly 4 times faster than the wheels. If you can feel the car moving from side to side (a waddle rather than just a shake), then the problem is almost certainly wheels or tires or hubs.
FWIW, the brand new brake rotors I put on my TR3 were substantially out of balance, right out of the box. I tried drilling them to improve the balance, which helped a lot, but now I think the rotors are warping. I'll likely be installing rotors from a different vendor, as soon as I finish dealing with the problems in the rear end.
