Shake, Rattle & Hum... CONTEST!!
Re: Shake, Rattle & Hum...
I found mine, a loose rear shock.
Good for you Jack! Isn't it nice to find & fix those annoying rattles & shakes?
Clue time:
Some bridges have these.
Great Jack, and you found it without Geraldo.
Pat
ROFLMAO!!! /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Some bridges have these.[/QUOTE]
Didn't someone already guess Jimmy Hoffa?
Morris, is in the lead.
Hmmm....
Clue time again:
- the larger part is thought to be lucky -
Green clovers?
Blue diamonds?
Purple horse shoes?
OK, you are talking about a wishbone, but that would be... what... the lower A-arm? Doesn't make sense.
Die, you found a die beating around.
Loose sway bar.
hmmm... I'm very tempted to declare a winner here....
/bcforum/images/%%GRAEMLIN_URL%%/smile.gif
ok, here's what should be the final clues:
Pachyderms have been known to work for them...
The cast of Scrubs frequently ask each other if they have a pair of these...
People usually go see a very expensive doctor whey they are feeling or acting this way...
Something you might like on top of your Sunday...
Anaphylaxis, a real problem for some people...
What a horse might do when frightened...
Nut
Gloves
Psycho
Cherry
Allergy
Buck
Hoooweeee, this is why I don't do the crossword in 'The Times'.
Oh is a buckeye nut.
What's a "buckeye nut"?
A Buckeye nut comes from the Buckeye tree. They drop in a green case and when you open them they are a shinny brown, folks use to carry them for good luck.
Peanut
Has to be a peanut.
