Gentlemen:
Related to my 1960 BE:
- How many amps should be the two fuses be?
- I dropped the fuel tank and installed a new fuel sender. With about 1 quart of gas in the tank the fuel gauge read full. Bad gauge?
- The electrical system has been acting very sporadically in the past week. We think we have a bad ignition switch. With the ignition on we don't get any power to half the fuse box. The headlights don't work, the blinkers quit working, and the fuel pump won't turn on, among other things. If the ignition is bad, can it be repaired? Or, is replacement the only option.
Any input is appreciated.
Mike Pennell
Mike Pennell
Hi Guest!
