chicken
I need to set my valve tapet gaps, from memory i believe this is 0.015" (i will have to look in the book) but i was told that there is a certain order to do this in (like start and 12 then go to 6 or something along those lines).
Is there such an order or do you simple start at one end at work your war along, also what is the best method for setting them.
One more question, should the fuel pump run continuosly or does it prime up and cut in and out, it seems to be pumping very fast and as the car is not running i assumed it would slow up even stop when it had filled the float chambers.
