I have taking the big leap an took my HS4 carb off to rebuild. I watched the video "Just SU" and felt confident that I could handle this repair. The only thing that is driving me nuts is how to set the needle in my pistion. Now the version of HS4 that I have has a spring loaded needle. This is where I need some direction. I have been trying to guess the height of where the needle should be located and once the dome is back on and move the piston up and down the piston gets stuck. I have been bending the linkage for the jet nozzle to help it line up with the needle but with it being spring loaded it moves with the adjustments. The only thing I didn't do was a jet alignment barrel. This is the part the the adjustment spring and screw get threaded into. The reason I did not do this was the piston movement before the rebuild was ok and the video said that if you don't have to take it apart don't. Any ideas would be great. I have been dealing with a idle and backfire problem since Oct 06 when I got the car. Timeing, Points, Vacumme Lines, and Clean Gas all good. So the only thing left was the carbs. After doing this repair I did find out that the stock valve and seats were bad and replaced with Grose sets. Also the linkage that is connected to the float jet was screwed to the wrong side(see Pict) Well got to go. Thanks /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Sorry I can't figure out how to load the pic. Yeah I am a Newbie
