Setting bonnet height at front?
Chris_Masucci
Hi Folks,
What locates the height of the bonnet at the front of the shroud? Is it the rubber buffers in the channel of the shroud or the latching mechanism?
Thanks!
BigGreen
Both, the mechanism holds it down with the buffers giving some tension
This is a good question for me too. If it lines up to; look right it bounces while driving. If tightened to no movement it sits recessed. I have matched the height and drive with dense foam under the front edge of the bonnet, laid in the channel. I have all the proper rubber bumpers in place to their max height. The bonnet is original and no front end damage.
AUSMHLY
Right you are BigGreen.
I'll add, that with some creative MacGyver tweeking, you can obtain the fit you're looking for.
The bonnet has a pair of rear hinges and a front striker pin assembly. You can make most adjustments with those to obtain a good gap fit and a flush alignment to the shroud.
To get the front bonnet flush, adjust the striker pin.
Once you have a uniform gap and everything is flush, then tweek the rubber buffers. You want the buffer to press up against the bonnet to keep it from vibrating or movement.
To adjust them, it may be as simple as having the hole for the split rivet in the right place.
If the buffer is too proud, then either cut the grove deeper to let it sit lower or shave some rubber off the top.
If you find that the buffer just isn't tall enough to make contact with the bonnet, make a spacer out of a thin sheet of aluminum. I just folded it in half and placed over the rain rail. If you're lucky the rivet will hold it and the buffer in place. If not so lucky (welcome to my world) then rivet the shim to the shrould first.
Just in case your wondering, the 3rd photo showing the end result of the shim hidden under the buffer....wait for it....that's not a scratch, it's the edge of the clear bra :smile:
Cheers,
Roger
Healey_Z
Roger,
Every time you post a picture I want to run out to the garage and polish my car....simply incredible.
Ken
bighealeysource
Bronze
Hey Roger,
Like Ken said, every time I see pictures of your BJ8 I am amazed at the quality. It is a beautiful Healey !!!! Plus like your hint on getting the buffers to sit a but higher as that would help with my BN2 bonnet.
Regards,
Mike
davidb
As a side note, you might also want to be sure that the bonnet/hood height at the back/windshield is set correctly as well. The previous owner of my BJ8 had it set too low, and with the constant scuttle shake, it actually wore grooves into the shroud. It's one of those things that you notice by accident.
Cheers
DB
B TR4/4A Some Help with Setting Distributor Triumph 47
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
C MGA Setting a 123 distributor MG 0
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
B Front Wheel Camber Setting Austin Healey 8
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
A Setting Camber Really Off Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
HealeyRick Why Setting an Auction Reserve is Important Spridgets 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
steveg Carb float setting tool Austin Healey 11
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
S Torque setting for U-Bolt nuts Austin Healey 12
K TR2/3/3A More on setting the timing... Triumph 12
petnatcar How to find the perfect ignition setting? Austin Healey 6
bugedd Setting Timing Spridgets 6
F Problem setting timing on my BT7 - maximum distributor rotation reached Austin Healey 14
mgedit TR2/3/3A Setting Valve Lash Triumph 14
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
C TR2/3/3A Dwell setting Triumph 11
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
S Procedure for setting and tuning HD8s? Austin Healey 10
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
S Idle Speed Setting versus Generator Output Spridgets 3
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
R Question on establishing a baseline timing setting Triumph 3
T Torque setting on brake rotor Triumph 4
B Setting door glass Austin Healey 3
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
R TR4/4A Tr4a, Stromberg float setting Triumph 6
M Carburetor tuning - setting mixture Triumph 6
T Setting up the diff carrier's gears questions?? Triumph 3
pkmh Setting Timing Mark For BJ8 Austin Healey 9
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
rlich8 TR4/4A A baseline setting on TR4A carbs? Triumph 2
J Setting Timing with a Petronix System Triumph 4
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
G Setting mixture on HS4 carbs MG 30
T HS6 idle setting Triumph 3
T H6S float setting Triumph 1
