Brosky
Thanks to my friend Tom in Madison, I was able to track down Scott Helms and obtain some "virgin" thrust washers from his inventory. I say that, as these are in the uncut and unpolished to size condition.
I spoke to Bob at Mason Machine and he and I decided that the best way to do mine, since it was out and we were starting from scratch, was to get these whole and Bob will set them up as a complete unit before machining the block/cap 360 degrees. After fitting to the exact size needed to fill a predetermined machined pocket in the block and cap, Bob will cut and polish these down, if needed, to a given size to allow for the proper movement of the crankshaft. I'll then have Scott cut and polish a matching set to Bob's sizes and I'll have a complete spare set, should I ever need them in the future.
I'm hoping that with the light aluminum flywheel, line boring and complete balancing, most of the bad things that can ADD to these going bad, will be gone.
Scott's site is back up and he has inventory available for those who may be needing these in one form or another.
https://www.britishcarweek.org/tr6.html
Hi Guest!
