Whitephrog
Anyone had experience with SEM Color Coat? About five years ago I received a set of black ribbed rubber door panel inserts as part of a package from Heritage Trim. I never got around to installing them on the original Whitephrog. About six months ago I decided to try to use them on the new Whitephrog. As the new Phrog had red trim I begin to look for the right product and color to use on the inserts. After way to much research I decided to use SEM Color Coat Flexible Coating in Portola Red (a great match to Cherry Red). The can reads that the product "is an elastomeric coating formulated to match, restore or change the color of plastic, vinyl, carpet and velour"
The problem is that after six months the painted surface of the insert is still a bit sticky. I discovered this a few days ago when I laid a lent filled cloth on the insert. The lent stuck to the insert. It will come off with some effort but I'm not sure I want to install these on the doors if I'm going to have this constant problem.
Advice??
Advice??
