Hap Waldrop
How the oil look, any debris?
SilentUnicorn said:You will find it easier to pull the whole unit. It will make life much easier on the re-install.
mark
racingenglishcars said:Just as an off shot, I'm betting on a thrust bearing.
Hap Waldrop said:The 1500 for race use doesn't really need the thrust bearings pinned because you not going to be sitting at a red light with your foot on the clutch, ....
64rocksprite said:Hap,
I'm in a similar situation with my 1275. I bought it rebuilt..but the more I think, the more I wonder if it was done right.
Would you have any tips for obvious things to check that would indicate the rebuild was a "quick and dirty" without having to completely disassemble?
What I can see are new AE 21252(1?) pistons, a clean surfaced flywheel with new ring gear and what look to be new exhaust seats in the head with cleaned original valves.
I'm guessing without tearing it down and putting the mic to things, there's no way for my un-trained eye to know the difference.
Morris said:Dear Scott,
Your slow progress on this matter is totally interfering with my life. Will you please get to the bottom of this engine seizure ASAP so I can stop obsessively checking this thread every 10 minutes.
Thank you,
Morris
