wkilleffer
Hello Everyone,
While doing a bit of fiddling around (yes, that's the scientific name for it) under the hood of my '74 MGB while it was at normal operating temperature. I just happened to notice that the back two head bolts on the outside of the valve cover, number 8 and maybe 11 in the torquing order, were bubbling. Not a whole lot, but enough to notice.
So, I let the car cool down a bit and went on to retorque all the bolts in the order to 48 lb/ft. I also wiped the engine down to see if there were any other seepage areas. After running it back up to NOT, only bolt 8 had any bubbles, and they seemed less than before. There was no evidence of seepage or bubbles on any other bolts, nor from the area where the head and block come together. There's no evidence that oil and coolant are getting mixed together.
Now, aside from having a somewhat cleaner engine, what do I have here? The engine's from a 72 MGB, and I've had it rebuilt between 9.5k and 12k miles ago (can't find the receipt with the mileage) by a competent service here called Rivergate. I will confess that I was more ignorant about maintaining a car like this back then (5 years ago), and no one told me to retorque the head bolts once per year until recently. It never occured to me that was a maintenance item.
Has my ignorance caused me to ruin my engine? I could *almost* do a head gasket job myself now, but don't want to need to. This wouldn't be a terrible problem except that this car is my daily driver and the only alternative save my motorcycle unless I can borrow a car from a family member.
So, what do I need to do? Drive it, take it off the road, or something in between? Any suggestions and advice would be appreciated.
Thank you, and have a happy and safe Memorial Day, while remembering those who made the ultimate sacrifice.
