Seat frame alignment with seat back
RestoreThemAll
I am reupholstering my seats. Where is the seat back supposed to sit on the bottom seat frame? I was thinking on the three tabs. It doesn't. Sits on the corners. See attached pic. Neither seat back sits very well on its bottom frame. Is that normal? Do folks add rubber or other type bumpers? Am I making sense?
Dale
Rob Glasgow
The seat bottoms sit on the bottom flange of the seat frame. The 3 tabs are the support the bottom of the seat back. Sometimes it is necessary to bend the tabs up or down to get them to contact the bottom of the seat back.
Rob Glasgow
I can't tell from your photo but I wonder if the seat frame has been modified to allow the seat back to recline more than normal. Does it look like the two tabs that hold the bolts that the back pivots forward on have been extended? If that's the case, the seat back will not follow the contour of the frame and will not sit squarely on the 3 tabs. Can you post a photo of the side tabs?
R
RestoreThemAll
The seat back doesn't hit the tabs at all. I don't think its been modified. I'll take more pictures tonight.
Dale
R
RestoreThemAll
I bent the bottom frame tabs up a little. One needs to be welded or brazed, as it's broken loose. I also bent the bottom of the back rest edge down a little to meet the tabs. I'm not fully confident that the thin sheet metal will stay put and not bend back. Not sure how to reinforce as the leather clips have to fit over. Ideas on that? See attached
I also notice that one of the holes that the seat back pivots go through is oblong. I'll need to fix that.
blueskies
Oblong holes for the pivots could contribute to the problem that you describe. As someone else suggested, if the pivot tabs have been extended to allow the seat to recline more, that also could create issues. What is the distance from the top of the lower frame to the top of your pivot hole?
R
RestoreThemAll
I didn't get a pic but we did take a measurement. 1/2" from the top of the frame to the center of the threaded stud that goes through the seat back ears. Does that make sense? Does it answer the question, if the mounting tabs have been altered?
Rob Glasgow
I think your frame has not been modified and is the way it came from the factory. The modification I added to my frame would have yielded a measurement of about 1-1/2".
That simple addition to those tabs tilts the rear seat back about 2" and makes the driving position much more comfortable, at least for me. Also in the stock position,I was looking out the windscreen just barely below the top rail. Now my view is several inches below the rail. It's a mod that is worth considering.
R
RestoreThemAll
Thanks Rob. In my 20s I was 5'11 & 3/4". Now I'm closer to 5'11'' and shrinking. How tall are you in comparison? I may not need the height reduction but the tilt could be nice.
Rob Glasgow
I was 6'3" when I bought the car in 1963. Down a inch at least now. But the real benefit is the more relaxed sitting position. Many other owners have done this conversion.
Deleted member 8987
All my life, high school onwards, 5' 11-3/4"......now after meeting the Scriptural Requirements of three score and ten, I am a tad under 5'9".
One of these days I'll be too short to get on rides at the amusement park.
R
RestoreThemAll
Three score and two, and retiring this year. I'll never really retire but I will finish the Healey along with a list of other stuff!
blueskies
It does not appear altered - maybe stretched a little, but still close to spec. Long-shot thought here, but is it possible that you have seat backs from an earlier Healey, possibly from an early BN4? The early BN4 and the BN1 and BN2 used a different seat base.
R
RestoreThemAll
The attached pic of the AHSPares seat diagram confirm that I have the correct parts.
The 3 pieces don't fit well. Look at seat pan. It doesn't drop down into the bottom frame.
I checked out the other seat that hasn't been taken apart yet. The fit is even worse.
I guess I'll have to modify all to make it all fit the best that it will. Am I the only one to find this problem?
  • AHSpares Seat diagram.pdf
R
RestoreThemAll
Look how nicely Randy's seats fit together. Mine won't fit that nice even before adding the thickness of leather.
R
RestoreThemAll
I discovered some of the problems.
I was looking at pics from Moss and AHSpares. On the new ones the back rest is straight looking from the center top to bottom. Mine had a slight curve at the last inch or so in an 8-inch area of the middle. Probably from years of use and abuse. A little creative tin knocking flattened it out which also pulled it down and back. It now rests very close to the tabs on the bottom where it’s supposed to.
In addition, I noted that the ½” lip on the bottom of the seat back that sits on the tabs is a little weakened by wear, rust, and someone creative tin knocking. I will add some extra support to that lip probably with some sheet metal 2” wide (tabs are1” wide), bent at a nearly right angle on the inside, epoxied in. Does anyone foresee a problem with that plan?
I also plan to glue on thin rubber bumpers on the frame tabs and the bottom lip of the seat back. Sound like a good plan?
On the seat pan that wouldn’t fit down into the bottom frame,I noticed that in the front where the pan is at a perfect right angle looking top to bottom in the AHSpare pic, mine bulged out some on both sides. Again, alittle more tin knocking and it fits into the frame now.
John Turney
If I understand correctly, the thin rubber bumpers will make the back sit up more vertically. Most people seem to prefer that it lean back. I have some washers under the front of my seat pan to make the seat lean back a bit.
R
RestoreThemAll
I've decided not to tilt my seat back. The rubber bumpers would be like 1/16" thick. I could add a washer under the front mount to offset the rubber.
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
Healey Nut Seat Base Frame Position Austin Healey 4
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
pbraun Bugeye seat back frame Spridgets 13
Popeye TR4/4A Seat frame - rust "repair"? Triumph 1
Tim Tucker TR4/4A Which seat frame do I have? Triumph 14
B TR3 seat frame issue Restoration & Tools 2
Shealey What does the fastener on the seat frame look like Spridgets 3
T MGA MGA Seat Question - frame bolt assembly pictures MG 4
T MGA Please, Tony, do find an MGA seat frame for me.... MG 3
T MGA MGA seat frame bottom - anyone have a spare? MG 3
J CP seat built on CF/CR frame - is it possible? Triumph 1
Rob_P How would you treat this seat frame? MG 9
AUSMHLY Seat bottom frame - painted or vinyl rapped Austin Healey 3
KLUTZ Wedge Good price for a TR7 seat frame? Triumph 4
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
