I took my front fender off, am redoing the suspension. the po painted the inner fender with black spray paint without prepping well, and I removed that as well. Nice original white paint underneath, very little rust. They also brushed on seam sealer on every caged nut, which kept all but one from rusting. My plan is to get the needed stuff done to get it back on the road rather than a full frame off, but not make things harder should I decide to do so later. so I don't want to use anything that will be really hard to remove later. What do you all use for the nonhardening seam sealer between the inner and outer fenders, and for cage nuts? What would you suggest for fender well paint?
