Ed_K
I have just recently installed a new pinion seal which has completely stopped the leaking from around the pinion shaft. Now that the gusher has been stopped, I can see that I also have some leaking around the gear carrier / front case. I will check the twelve nuts to make certain they are all tight but if they are all tight, Is it possible to loosen them all up and split the front carrier /case away from the main case say about a 1/2 inch in order to clean the surface and then reseal it with a bead of form-a-gasket ? Or will the inards fall loose inside the rear axle ? ... Nothing worse than loose inards !
Any other suggestions how to seal it back up while it's in the car ?
Thanks,
Ed K.
Thanks,
Ed K.
