climbingshuksan
An old sealing repair to a 1963 Austin Healey brake/clutch reservoiur never held well. In re-working the reservoiur the original fitting lacked any rubber washer or any such washer(s) between the fitting and the tin can. On this reservoiur some kind of alloy type "washer" appears to be original. It's not a true washer in that it is fused to the clutch fitting. It no longer seals - likely due to changed shape from previous repairs. Best fix? A rubber washer? I've seen an image of a similar reservoiur apart. However, rather than this fitting - it has what looks like a normal thin style washer with some kind of rubber fused to it.
