TR2/3/3A Scuttle uneven on one side
DennisT
Member
I have about a 3/4” difference on the pass side of my scuttle which is enough that it causes the windshield to slope down on the pass side , it is noticeable when looking at the front end dead on. The rear deck is perfectly even. I took some measurements and it appears that the dimension from the floor to the tip of where the scuttle ends on the side of the vehicle, (by the uppermost top of the door). I was thinking of taking the outer sill off, raising the portion of the body tub just back to the forward mounting bracket of the inner sill. I was thinking of doing this with the door attached to make sure I can still get a good fit. I am open to suggestions as to how to approach this problem.
sp53
Yeh that is a difficult one. How does the windshield bottom rubber fit the cowling? I have seen cars with a 3/8 inch under the cowling on one side where you could put your fingers under it. In that case the windshield frame itself was bent. I think a combination of the upright and the bottom piece holding the glass which sounds wrong, but it was the case. How about the interior kick panels is either side dented from accident damage? Does the windshield slide off? Some pics would be good.
steve
charleyf
Bronze
The car I am presently working on also had an uneven cowl. I subscribe to the theory that to straighten the cowl you need to only work with the cowl. That is from the top of the doors and up. I recall that I was able to improve my situation by lifting the low side with a jack between the floor (which was bolted to the frame) and the underside of the cowl. Note that there is a reinforcing piece under the area where the hinge sets. I used that point under the dash
sp53
Sure the cowling basically cantilevers out from the tub, so it is weak. The inner kick panel is the support for the cowling, so the arc stays the same. Taking off the outer sill IMHO will not let you change that opening or let you lift a specific spot. These cars settle over the years and couple of times I have seen the sheet metal rip on the lower part of the cowling letting the back corner come down, but usually the door settles down and leaves a larger gap at the back tip of the cowling. It sounds like the door works fine without hitting the cowling, so that is cool. If you have the carpet out, take a mirror, if it is an early car, and look around through the hole on the PS side. It might be the low side is correct and the other side too high.
steve
DennisT
Member
Thanks for the responses, I will try to post pics, I did try to jack the cowl but I chose the garage floor and the rear edge of the cowl underneath where the grab rail mounts, I fashioned a curved piece of wood between the ram and the underside of the original wood stiffener. I realized it would not budge due to the inside metal stiffener by the curved part of the cowl, maybe I will check to see if there is a support under the hood hinge holes on my car, not sure if I have that piece , my serial # is about 1900.
DennisT
Member
Another piece to this puzzle is that the pass side door/cowling gap is tight and the door sticks out about 1/8 “ from the cowl. It appears the there is a slight flat spot at that point right above the door. It must have been hit hard right there because that is where the metal stiffener is and I can’t get behind the cowl to work the metal
DavidApp
Hello Dennis
When you have your post ready then go to the row of icons above where you are typing. Click the third icon from the right hand end. That should bring up a box with From computer and chose a file. Follow the directions to add your image.
David
CJD
Very hard to tell in a single pic...but in that one the rear scuttle looks low on the left. I can’t see the problem with the front.
Graham H
Dennis, if you are using an iPhone to take the photos you need to hold it so the volume buttons are facing up so that they come out the right way up . This forum uses windows so it will not rotate the photos, I have had the same problem.
Graham
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
C TR2/3/3A scuttle vent Triumph 6
steveg Steering column steady brace and scuttle shake? Austin Healey 2
Darwin Spitfire scuttle vents Triumph 0
M Scuttle shake. Austin Healey 16
D Scuttle shake and tyre pressures Austin Healey 2
R More Shroud to Scuttle install Austin Healey 4
L TR2/3/3A Scuttle / front fender attachment Triumph 9
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
N TR2/3/3A TR3 Scuttle Vent Triumph 13
N TR3 scuttle vent FORUM Help 1
C TR6 Scuttle lid spring? Triumph 6
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
B Scuttle shake finally sorted Austin Healey 23
PAUL161 T-Series Scuttle Shake/Vibration MG 6
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
J Door/scuttle rubber seals Austin Healey 2
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
S Scuttle Shake Austin Healey 95
H clear coat question on scuttle Austin Healey 7
PatGalvin Scuttle Vent Rubber placement Triumph 4
5 The scuttle shake mod- I can't decide Austin Healey 7
steveg Scuttle Seal installation article Austin Healey 2
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
M Sebring Scuttle Vent Austin Healey 3
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
H Scuttle Seals Austin Healey 2
curtis BN2 scuttle seal Austin Healey 13
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
richberman Scuttle Shake solutions, necessary? Austin Healey 24
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
H TR2/3/3A TR3A-Scuttle Vent Ass,y - Parts Missing Triumph 3
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
C scuttle vent linkage Triumph 4
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
ekamm scuttle knob Triumph 6
M TR2/3/3A Tr3 scuttle mechanism Triumph 2
S TR6 76 TR6 Scuttle Vent Triumph 16
O TR2/3/3A TR3 Scuttle Panel Still Needed! Triumph 5
O TR2/3/3A TR3 Scuttle Panel Triumph 8
G Scuttle Vent Adjustment Triumph 1
Tinkerman TR2/3/3A Scuttle Vent Installation TR3A Triumph 4
mjobrien Chassis to Scuttle - Gasket - Filler - Foam? Austin Healey 13
TonyPanchot TR5/TR250 tr 4/ 250 scuttle vent gasket Triumph 7
M TR6 TR6 scuttle panel drain Triumph 17
chicken How is the scuttle top liner held down Austin Healey 14
