metropolisman
Good afternoon,
i have posted about my car before. One thing has lead to another and because of the inequities with my car I’ve elected to do a full frame off restoration.
I took the windscreen off and discovered that the previous caretaker had not only installed the wrong year shroud but that they took a short cut and hid the parting line under the windscreen it is completely disconnected from the dash, would this contribute to scuttle shake?
The car obviously took a major broadside as the scuttle support on the frame is bent inboard. I noticed a small crack at the shock mount.
I’m inclined to replace the shroud and straighten anything bent, weld the fissures properly and make sure the frame is straight. If anyone could lend a bit of advice I would be deeply grateful, thanks - jeff
