Scuttle shake and tyre pressures
DavidThorn
The car is a late BJ8 with 165 radial tyres on bolt on wheels.
I was running it with pressures of 25 front and 27 rear and had scuttle shake at about 55 mph, the steering also reacted badly to potholes in the road surface,we get a lot of them here in the UK!!
Hitting such a hole would send quite a shudder through the steering , its got a recent Denis Welch steering box and I think all the steering joints are good ,
I recently increased the pressures to 27 front and 29 rear and both issues seemed much improved.
Any thoughts?
David Thorn
Here across the pond, we do the "pothole slalom.
I'm told that your new tyre pressures are about right. I run mine at 35 psi all around, although I have 195/65 tyres, to keep from scraping on exiting my driveway.
Do you have the scuttle shake at 55 on smooth roads?
Any thoughts?
David Thorn
Scuttle shake can also be cause by rear brake drums out of balance, tires out of round( you can balance a out of round tire, but it will not roll true).
